I rigged a 120mm fan on to my heatsink. It has dual power connectors, one 3pin for the mobo, and one 4pin molex for the power supply. I only plugged in the 3pin mobo connector so it could be temp controlled, etc... but on two occassions I've got the fan coming to a complete hault while in operation! I immediately turned off the computer both times...
So I was wondering, before I go ahead and do it anyways, is it safe to plug in both the 3pin mobo for speed control and the 4pin molex for "security", or was I supposed to do that to begin with since it's such a big fan???
Probably a simple/common/every-one-already-knows question, but it's a nitty gritty speciality question for me.
Thanks.
Thanks.
