Originally posted by: JBDan
I use these in my Tsunami and they are practically inaudible. If your a stickler for silence you WIL NOT find an equal. http://www.silenxusa.com/produ...ry=31&idproduct=43
Comes in green and red as well 🙂
I meant to say for the CFM/DBA ratio you will not find an equal. 12cfms seems like very little to me do you have any heat probs at all? That is quiet lol I must admit though. 😉
yeah i know, they push low CFM compared to others, no heat probs.. i mean the case gets ventilated.. there is not much of a draft so to speak, but everything is low RPM in my PC and it runs like a charm, even with an OC'd 6800GT. there is airflow, just a nice quiet breeze though.. the loudest fan in my PC (I just tested) is the 92mm vantec stealth on my XP-90.. sounds like a bearing more than airflow noise. damn.
Originally posted by: flawlssdistortn
What about replacing the 90mm fan? It's an odd size, so I haven't been able to find an LED fan replacement for it. Any ideas?
lol replace it!!!
I love silence as well 🙂
lol replace it!!!
I am thinking of getting the 1600RPM model of the Silenx 92mm fan. Just gotta find a cheap place to buy it from and I'll get it... the Vantec definitely has a loud bearing. I think I might trade in my PSU also for something even more quiet.. it's not loud, but i can definitely tell it's there.. (X-connect)
Originally posted by: rpv
http://www.silentpcreview.com/article63-page2.html
http://forums.silentpcreview.com/viewtopic.php?t=16393
I wanted to replace them too...I realised that the "quite" 120mm fans cost around $20...(exception was the globe fan but was backordered)...Wasnt sure I wanted to spend that much on a fan....Decided to hold off as I wasnt very uncomfortable with the noise level with the stock fans....cools very well too.
Originally posted by: smoothness
i've heard that silenx is a bit of a shady company, and they boosted their own rep on www.silentpcreview.com i suggest nexus, especially since someone found a stock retailer for their fans, and you might be able to get them real cheap. the manufacturer of nexus fans are yate loon. look it up - you'll find a lot of silent pc modders consider them the holy grail of fans.
Originally posted by: Edward Lee
I think the stock fans in the Tsunami are just as quiet as any of those fans mentioned above. I don't think you'll see a noticable difference. Better to invest in some sound insulation or maybe a fan control. The fan controls look cool in the box BTW.
