Muse
Want a 120mm, 140mm or 200mm 12v fan, not for my desktop (which already has one), but to get some ventilation in my smallish bedroom. The room is around 90 square feet, around 8.5' x 8.5', is on the 2nd floor, so it gets warm late in the day and is slow to cool at night. I used to leave my screened window open and this let some of the cool evening air in, but I installed a window air conditioner last week, taking away the open window option. I don't want to have the air conditioner on all night. The compressor's either working or it isn't, and when it isn't the fan just sucks air from the room and pushes it back in the room... no option to suck in outside air. Besides, the air conditioner's fan is just too loud when I'm trying to sleep, even on the low setting (it has high and low, but there's not much difference in terms of noise). I figure I'll use the air conditioner occasionally to cool the room quickly but for sleep time it really isn't great.
So, my idea is to remove the accordion panels from the air conditioner and put a solid panel in with a 120mm, 140mm or 200mm fan attached, which will actually suck outside air into the room. I set this up last night (using Owens Corning film covered 1/2" insulation), but the fan I have is too noisy, a Panaflo 120mm. I used a 12v wall wart I have that was evidently for a Panasonic cordless phone. The Panaflo fan, however,while pushing a lot of air, has a pretty loud distinctive hum.
What I want is a fan (maybe 2) that pushes a LOT of air but isn't grating in terms of noise. Some noise is OK, in fact I want some noticeable noise, just not noise that would hurt my sleep pattern, IOW white noise! Thing is, my neighborhood can be pretty noisy, so white noise is a good thing for me here. Before I put in the air conditioner in warmer weather I'd leave the screened window open and wear ear plugs to combat the neighborhood noise. For the fan(s), pretty much the more air pushed the better, not sure how much of what kind of noise I want -- enough to mask the neighborhood noise, but not so much that it wakes me up.
Can I get suggestion(s) for fans that push a lot of air and make what might be the right amount of "white noise?"
