Catleap !
I have the asus vg236h and love it
BenQ XL2420T
Your going to need more GPU horse power before you upgrade to a 120Hz monitor otherwise just get a real nice high end 60Hz. I would suggest a Catleap before a 120Hz monitor.
You don't need to have 60fps to run a 60Hz either but it's always ideal to have the FPS at or above the monitors Native refresh rate for the highest performance and best most enjoyable experience. 120fps is a far stretch in many games even for the 670.You don't need to have 120fps to run a 120hz monitor. Why does everyone think that?
Samsung does the job x3 for me, but I also like Displayport over DVI, so check which model of the S23A7XX you want.
The best advice I usually see is to get over to a b&m where you can see a few side-by-side and make a judgement based on your own experience.
You don't know what you're talking about. I can go above 60fps in a lot of games. I don't know why you think I can't. You don't have to have 120fps to have a use for 120hz. What if I wanted to do 3D too sometime? 60hz can't.
QUOTE]
Typical of you to follow what everyone else thinks because it is Popular but IMHO higher resolution is always better than try to get high frames rates in games to take full advantage of a 120Hz monitors full benefits. Thanks for the personal attack by the way.
That's just it, no B&M store near me stocks any 120hz monitors. I don't have a Fry's or Microcenter around here.
Speaking of Display Port is there a difference between it and HDMI or DVI in terms of lag or latency? I've heard some people say that HDMI introduces a bit of delay. Is this actually true?
BenQ XL2420T is nice in that it has a height adjustable stand. But Asus is cheaper and comes with 3D glasses... so if you don't care about height adjustability and want to try out 3D, go with Asus.
