QuantumPion
I have the LG and have been liking it a lot. I miss the quality of an IPS but I doubt I could go back to 60 hz.
i've got an S23A950D in my online shopping cart. come April, i'm gonna press the Buy button. sadly, after taxes and all it costs the equivalent of 600$ here 🙁
Vega said:Anyone ever run the Pixperan program before: http://www.prad.de/en/monitore/testsoftware/pixperan.html
On the readability test of super fast text there is a speed scale from 0 to 30 (30 being fastest). On the FW900 I can read the text at speed 30, and on the 2ms 120Hz Samsung's, it's 4!
I knew CRT's were always faster at movement, but not this much faster... 😱
elvn said:I was guessing on the 5 speed myself when I ran the same test on my 120hz samsung.
Its the smear/blur during motion. CRT has none. LCD's have it bad. If you run the readable moving text test on your screen you would see 60hz lcd unreadable at the first few speed increases, and the 120hz lcd would get maybe one more speed increase out of it. The crt would be readable to max speed since it doesn't blur. Now consider an entire scene of 3d objects and consider objects and modern high detail texture detail "read" by your eyes, including virtual depth via bump mapping. Every time you move your FoV quickly, an LCD will smear that out. On a 120hz, at least the blur goes out of bounds less from the outline of the object if you get what I mean.
.So this isn't about frames per second shown like a movie, this is about panning your viewport with relatively fast to very fast FoV arcs, and back and forth arcs that are tactically advantageous to keep apprised of whats going on around you in 3D environments, to pinpoint new targets, etc. Generally any moderately fast FoV movement. When you do this the entire scene blurs on LCDs, as the pictures I posted tried to simulate. The crt in the middle of two 120hz lcds picture of skyrim afk FoV spinning pretty much sums it up. The lcd's blur their view of the scene while its moving, while the crt doesn't.
http://web-cyb.org/images/lcds/fw900-and-23in-120hz-sides_vega.jpg
No. The only display technology that updates all at once is dlp projectors. In LCD panels, only one pixel changes color at a time.No expert here, but:
CRT are refreshed by a sweeping electron beam form left to right (I think) and from top to bottom while LCD screen is refreshed all at once
So the blurriness won't be noticeable in the CRT because they rely in the image persistence on the screen.
The critical difference is that in CRTs, only one of the pixels is really bright at a time. Most of the screen is just plain black most of the time, with a single really bright pixel racing across the screen. (easily provable with a fast-speed camera). Because our eyes suck, this kinda looks like a stable evenly-bright picture, only not quite.
Got a Planar SA2311W in the mail. So excite.
Ive been considering ordering that too. Let me know if its good. Newegg used to have it for $280 but are now oos. Tigerdirect still has it for $280 though.
Hi. I registered since I read this thread a few times and have borrowed a few pictures from it to illustrate the points made here elsewhere. The blur photos are simulations and I believe both were defined as such in their posts. They are fairly accurate but don't show the blur/smear ghosting outside of the onscreen objects.
Here is an actual photo I borrowed from another forum. It shows a fw900 graphics professional crt in the middle of two 23" 120hz samsung lcds during the skyrim afk FoV endless spinning. The lcds blur while the crt does not. It pretty much sums it up. That said, I do own a 120hz samsung and they are appreciably better than a 60hz but still blur.
That photo makes the 120Hz panels look rubbish. If I was unsure and I took that photo at face value I probably would not bother buying one.
Anyone who is on the fence about the improvement 120Hz offers over traditional 60Hz displays really needs to go out and test a 120Hz screen for themselves.
As long as your rendering close to 120FPS the difference on a 120Hz panel is night and day.
Actually you might want to jump on it now. I'm expecting it Friday and they might all be gone by then. It seems like TD and Newegg might be clearing stock and this might be the EOL for this monitor. I just got a message from TD (where I ordered mine from) saying that returns aren't allowed on this monitor and Planar would be handling all CS for it. I'm not sure if this is common?
In contrast, while LCDs still only modify the brightness of a single pixel at a time, once set, the pixels remain that color and brightness until they are modified again.
Interesting. Yeah I dont know.
Newegg just put up an auto-notify button on the planar monitor which was not there before. I put my email in just to get notified. Are they being discontinued?
I am still trying to decide between that planar and the viewsonic VX2268WM 22" 120hz. Its about a $90 difference and I am not sure the planar is worth $90 more even though it is a newer updated model. I found the viewsonic for $210 with free shipping on a site so thats pretty damn good for a 120hz monitor. I dont know if I should just spend the extra $90 for the planar or get the viewsonic, all I really care about is 120hz so...
I am also looking for a 120Hz display.
The question I have is that for ATI cards that are newer then the 5xxx series is the only output that can drive 120Hz the mini display port?
Also am I right to assume that for Nvidia cards that they use the HDMI ports?
