http://www.pcconnection.com/ProductDetail?Sku=6732798
19" HC-194D Analog Digital LCD Monitor Black
Price:$239.95
Rebate:-$120.00
After Rebate:$119.95
Product Specifications
Connectivity
Connector Type VGA
Connector Type DVI
Connector HDDB15 (F)
Connector DVI-D 24-pin (Dual Link) (F)
General
Color Black
Attributes Dual speakers
Performance
Response Time/Rate 8 ms
Dot Pitch 0.294 mm
Compliant Standards CE
Compliant Standards CUL
Compliant Standards UL
Compliant Standards Energy Star
Compliant Standards TCO03
Compliant Standards FCC
Video
Digital Video Standard Digital Visual Interface (DVI)
Display Size 19 in
Display Technology LCD
Image Brightness 250 nits
Color Support 16.2 million colors
Contrast Ratio 700:1
Internal Resolution (maximum) 1280 x 1024
Viewing Angle (H/V) 150/135 degrees
Display Type Standard
Actual Weight 11.2 lbs.
Compatibility Notes Audio: 1W x 2 Channel Built-In Stereo Speakers
Tilt: 0º~20º Vertical Adjusting Stand
VESA Wall Mounting compatible
Contents Monitor, DVI cable, VGA cable, audio cable, power cord, CD, documentation
Power Notes Input Voltage: 100VAC~240VAC, 50 / 60HZ Autodetect
Power Consumption: 42W Maximum, <1W Stand-by Mode
Warranty - Labor 3 Years
Warranty - Parts 3 Years
Price:$239.95
Rebate:-$120.00
Connectivity
Connector Type VGA
Connector Type DVI
General
Color Black
Performance
Dot Pitch 0.294 mm
Video
Display Size 19 in
