- May 31, 2001
- 844
- 36
- 101
I recently mounted an ARCTIC F12 PWM 120mm fan on my case's (Rosewill Redbone) side panel. It is oriented so that it pulls air into the case since my AIO radiator is mounted on the back of the case with the fan on the radiator blowing out. This helped to lower my CPU (i7-4770K) temperatures from 60C full load to 52C full load.
However, the fan makes a lot of noise since it's pulling air in through the perforated side panel. I intend to get a dust filter to put over this so I don't pull dust into the system. Will the dust filter also lower the noise of the fan or will it make it worse?
