12 gram co2 adapter help HELP ME!!!!
BadNewsBears
3,426
I need something that wilol replace the 12 gram witha 9 ounce tank. Like 12 gram tank on one side goes to hose goes to 9 ounce tank. How do i do it?
Anubis
78,712
427
tbqhwy.com
a paintball supply place might be able to help youout with that. but if you had a 9oz tank why would you need the 12 gram
Anubis
78,712
427
tbqhwy.com
then just get a remote hose and connect it to the 9oz and screw the other end into the gun. that should work
MrBond
9,911
Originally posted by: Munchies
Cuz its a bb gun that uses 12 grams and my friend gave me his old 9 0z
Who makes the gun? If it's a Sheridan, there are SOME adapters out there, but I'm not sure how well they'll work with a pellet/bb gun (they're designed for the paintball guns sheridan also makes). Check out www.funsupply.com (I think that's it), and look for accessories by Cooper T. They make one adapter that replaces the 12gram/plug and has an adapter so you can attach a bulk co2 tank.
BadNewsBears
3,426
Its a non threaded 12 gram that is conncted by poshing it in to pop the top witha big screw type thing
Anubis
78,712
427
tbqhwy.com
ahh i cant help you out there maby check out that pahe mentioned sheridan makes just about everything so.....
