Markfw
- May 16, 2002
- 26,129
- 15,274
- 136
And while posting and catching up on other posts, the usage went up to 17, now 18 gig and still rising. I just stopped a major disaster from happening, 3 crashed box (or 4)
Sell the older stuff (though It looks like your stuff is all pretty new and get 4000 series Ryzen gear in a few months?)All done... The three threadrippers I have sold had all that extra memory. Now all 3 3900x are at 32 gig and the Xeon !
And the 2 I did that were not locked up were using 14.5 gig of 16, so any minute they would have been a problem.
I have WAY too much hardware. I have 3 functional boxes not fired up, as I don't have the power to run them, including a 14 core 28 thread Xeon.
Edit, and I changed back the box that I had to switch to WCG, so now all 3 3900x's are on Rosetta, the 3950x, all Xeons and EPYC's, and a 2970wx and a 2990wx.
I just sold 3 1950x's recently, and the 14 core Xeons, I can't even get $200 for, might as well keep. Thr 950 I7 I have I will keep for old games, and the 4790 keep for old work thinks I might want to look up. So nothing saleable left.Sell the older stuff (though It looks like your stuff is all pretty new and get 4000 series Ryzen gear in a few months?)
Sounds like the same reasons I still have my core 2quad and APUs.I just sold 3 1950x's recently, and the 14 core Xeons, I can't even get $200 for, might as well keep. Thr 950 I7 I have I will keep for old games, and the 4790 keep for old work thinks I might want to look up. So nothing saleable left.
I think I'll go look up MemDoubler on Aminet. ;-)you should be able to configure zram on Linux systems to create a Dynamically sized, compressed swap Partition in ram,
With a bit of balancing, I am still able to run all my computers in a single room on two circuits (16 A breakers, 230 V). But to be safer, I moved a triple-GPU computer into the kitchen on another circuit.I have WAY too much hardware. I have 3 functional boxes not fired up, as I don't have the power to run them,
lol! In all seriousness, zram does work. my pi 3B+ is functioning like it has 3.5gb ram, even though it only has 1gb.I think I'll go look up MemDoubler on Aminet. ;-)
Ah, yes, I'll definitely use this suggestion instead of the confusing and overly complicated stick-throwing contest.Looks like too much or too complicated to digest? Ignore the details. Simply run Rosetta@home for TeAm AnandTech for the duration of the Pentathlon. :-)
Thanks!
Hello, Assimilator1.Hey! Good to see you mate!
How's things?
Thanks!
With CreditNew used at NumberFields, it may turn out more like a spaghetti throwing contest. ;-)Ah, yes, I'll definitely use this suggestion instead of the confusing and overly complicated stick-throwing contest.![]()
Is this how we get ahead of the other teams then? Have everyone who can’t buy more ram configure zram and keep their Linux systems at max processes?They released Rosetta v4.20 for linux and RAM usage definitely went North! The previous version (4.15) was fine on my 3700X with 1 GB per thread but am now seeing "waiting for memory" and swap file usage so I cut back to 14 threads.
I have 15 amp breakers on 110/120v. That 230 volt doubles your capacity., so 4 of my circuits. Well, guess what ? Thats the 4 circuits I use.I think I'll go look up MemDoubler on Aminet. ;-)
A year ago shortly after I moved here, I fixed a wall outlet — which doubled as junction box — which got hot and smelly when I had high load on the respective circuit. I still have several outlets which get warm now (but not actually hot), and should look into that after the Pentathlon.
On the box I am typing, I have 2 3600 cl16 and 2 4233 cl19 running 3200 cl16. better more ram than faster/better cl ratings.It looks like these tasks are taking more than 1 GB of RAM:
Junior_HalfRoid_design5_COVID-19_SAVE_ALL_OUT_IGNORE_THE_REST_3ii3yt0o_924662_15
I do have another couple of 8 GB DDR3200 RAM sticks but they are CL16. The RAM in the box is 3200 but CL14. Normally I would jump off the roof before mixing vendor/timings RAM in the same rig. I guess I could drop them in and do a short memtest to see if it's ok.
@Endgame124, and which memory settings in BOINC go with it? Allowing high RAM percentage and high swap percentage?
If I’m reading top correctly, kswapd has been running 158 minutes over the last 6 days on my pi. It seems to get busy every 30 minutes or so for 10 seconds, then goes idle, unless I pickup one of the really ram heavy WUs, then it is busy more often.BTW, on computers with Intel HyperThreading, the drop in Rosetta throughput when not using all processor threads should be rather moderate. The loss is probably higher if AMD Zen/ Zen2 SMT cannot be fully used. (Luckily for me, my Zen2 CPUs have enough RAM attached to use all threads at Rosetta.)
Also, how much is the gain really, compared between a computer which uses fewer processor threads, and a computer which uses more or all threads but has Rosetta performing accesses to compressed memory? Edit, my guess is that accesses to compressed pages may be infrequent though. Rosetta is not excessively sensitive to memory speed from what I remember, despite its large memory footprint.
How do you get 4.2 ? mine are all on 4.15 I thinkThey released Rosetta v4.20 for linux and RAM usage definitely went North! The previous version (4.15) was fine on my 3700X with 1 GB per thread but am now seeing "waiting for memory" and swap file usage so I cut back to 14 threads.
Well, I won't see 4.2 until Tuesday, as I am bunkering.....All my new tasks are v4.2, currently on 4.15 with 10 threads it's using about 3.9 GB with a mix of tasks taking 400 - 1200 MB.
With 32GB for 'just' 10 threads hopefully I'll be ok!, the 1st 4.2 task will start in about 4 hrs, actually 6 of them will all start close after each other.
Earlier this week, when v4.15 was current, I ran Rosetta only on 4 cores, therefore I don't have much data. But I recall seeing about the same pattern of RAM requirement as I got today from my 256 tasks sample in post #58.my 2990wx boxes only have 64 gig ram, and one of them is running 50 gig used. running 4.15. What do you think it will use under 4.2 ? more than 62 ?
I see the graph, but not sure what its telling me. I guess I will have to see Tuesday the average for 12 core, 16 core, 24 cores and 32 cores with SMT on.Earlier this week, when v4.15 was current, I ran Rosetta only on 4 cores, therefore I don't have much data. But I recall seeing about the same pattern of RAM requirement as I got today from my 256 tasks sample in post #58.
