10mbps = 1000KBPS, right?
Originally posted by: BCYL
KB = KiloByte
mb = megabit
1 byte = 8 bits
so 10mbps = 1.25MB/s...
And 10mbps is pretty rare for a broadband connection is it not?
Isn't most ISP's bandwidth capped at 3mbitps?
Originally posted by: Demon-Xanth
10mbps=1000KB/sec+protocol loss
Thanks, just making sure. This guy is claiming to have a 10mbps connection and I just don't believe him. he is also saying Verizon offers a 100mpbs connection for $34.95.
:Q
Nocturnal, 10mbps is usually 10000kbps (kilobits per second), which is 1250kBps (kilobytes per second), which is 1.25MBps.
it depends
if you are talking real throughput you also have to shave some off for overhead
they usually use the bits per second number vs the bytes per second so that it sounds faster
what would you do with a single bit? you need at least a byte to mean anything, so measuring it in bits is silly
FoBoT: not all computers have always used 8bits/byte. I've heard of old systems that used 9 (and not just parity). And by saying bits, you can account for protocol loss. An example is in a modem handshake you can have 8-N-1. 8 bits, no parity, 1 stop bit, that makes 9 bits per byte transferred. Another example is 8-E-1.5, which makes 10.5 bits per byte transferred.
Fill in the blank...
Can some explain the relation ship of bandwidth to actual data size?
1 Byte = ? (A single bit?)
1 MegaBit = ? (128Kb or KB?)
We have a 10mbps NMLI, but we pay a good bit more than that...
1 Byte = 8 bits
1 MegaBit = 1000 Kbits = 125KB
To put it in real world terms, I have 10 Mbit BB at home, and I usually top out around 1.1 MB/Sec, slightly above that.
