- Jan 7, 2007
- 4,079
- 1,574
- 136
so all the cool kids seem to be using 10bit color to encode their anime now.
-i tried using latest mpc-hc with latest cccp, which others claim works out of the box. no dice for me.
-smplayer which is supposed to be an all-in-one solution didnt work.
-latest mpc-hc bundled with klite7.8 and 64bit extra pack works, but it screws up some older 8 bit mkv's(audio plays, but video stutters or gets stuck cycling between 2 frames).
is there some sort of diagnostic to figure out what mpc is glitching on? or should i just wait for an later update and hope it fixes my problem?
(edit: fyi 10bit is used to reduce file size and reduce color banding/dithering. most source material is 10bit originally -> 8bit compression ->8bit encode. going 10bit -> 10bit encode eliminates a step and uses highest quality source for the final image)
