ok - is it just me - but now we're starting to see some HD DVD rips out there, its seems you need a different player for each one of them. Before, I could use VLC to play pretty much anything, but now most of the rips either show no picture or play at about 5 FPS. Most of the HD movies I've got are either .ts files or wmv files. THe wmv files aren't too much of a problem cos I can play them in power dvd or windows media player, but the ts files don't seems to work properly on anything
I can get it running ok on Zoomplayer but every few minutes it will start to stutter - the same with media player classic
Any body know if there's a codec out there that needs to be installed to play these files? I have cccp and vista codec pack with the 64bit addon (running Vista64 obv)
THanks in advance!
THanks in advance!
