- May 9, 2005
- 2,044
- 1
- 81
I have a 1080i tv I want to use with my HTPC. I am having a problem getting it to go to 1080i 60Hz. It will do 1920x1080 at 29 and 30Hz but it has a noticeable "vibration" to it. It will do 720p at 60Hz no problem and looks great. But I would like to throw a blueray drive in the HTPC in the near future and watch it at 1080. The sticker on the back of the tv says 1080i and underneath that says 60Hz. Now, that 60Hz isn't directly next to the 1080i, so did the tv company (mitsubishi) slip a curveball by me? Yes it will do 1080, yes it will do 60Hz, just not at the sametime! Another thing, is 1080i only 30Hz and 1080p 60Hz? If so, how come I don't have any problems playing the Xbox 360 at 1080i? Wouldn't there be some sort of "vibrations" for that too? Both the HTPC and 360 are hooked up via HDMI.
The specs of the HTPC are:
E6600
HD4850
4gb DDR2
bla bla bla....
Thanks for the help!
E6600
HD4850
4gb DDR2
bla bla bla....
