1055T Temps
Ruger22C
1,080
4
What are the safe temps?
Do I go by CPU temp or each CORE'S temp? They are drastically different.
I have heard (and believe) the 1055T has a sensor issue, being 10-12c off? Can anyone give me more information here, maybe an article telling me if it's 7c, or 10c, or...
Dec 30, 2004
12,553
I am quite sure my core is not colder than my room, Soccer. ;)
The chip reports a temperature that's always in reference to some number. IE, in reference to 100C, it would report "70" if the cpu were at 30C.
If a program thinks your chip is referencing to 90C, then that would cause your temp to be read as 20C, which is less than ambient temp (usually 23C).
Ruger22C
1,080
4
Yeah I guess that big hunk of metal with a fan on it plus native undervolting/underclocking wouldn't allow for such a feat :rolleyes:
I hope you're being sarcastic.
It CANNOT be colder than the air moving across it, without refrigeration or similar device.
Ruger22C
1,080
4
Okay.. but my core temp goes "higher" when I'm @ 100% load. So, it can't be that.
tommo123
2,617
48
im using coretemp (stock clocks) and it hits mid - high 30's (C) with stock cooler
