1024x768 max on a Nvidia Riva TNT2 Ultra (w/ P3V4X)
beafer
I know this is not right for this AGP video card, but i think it has something to do with the MB. Any suggestions?
When you say "max" do you mean under the display properties??? If so what driver are you using??? The newer Detonator 3 driver 6.XX series are not the fastest for those cards but most are very stable... Try 6.26 or 6.27 and then see whats up... Also what monitor is listed also that would possibly limit your res...
You are using your IBM 2124 model monitor, but do you have the drivers installed for it? When you look at your display settings, does it list your monitor, or say something link "svga monitor"? If windows doesn't know what monitor you have installed, it might will probably limit the resolutions you can use...
And also, when i first installed the TNT, it never found it, as "Windows has found new hardware" box that comes up, even after i made it search for new hardware, nada. Some how some way i got the drivers installed and that is when it came up with that max resolution.
Thanks bartman on the monitor limits. I just went to IBM site and found the limits for this monitor, which is 1024x768. But if you can tell me where to get those drivers, that would be even sweeeter. Thanks for the help and the quick response.
