1000 shader APU - when?
Enigmoid
2,907
31
Enigmoid, Maxwell has twice the number of ROPs. It's not totally surprising that it has higher pixel throughput.
The consensus seems to be regardless of the ROPs, colour fill is bandwidth limited. 290/290X vs. 280X doesn't scale anywhere near 2x. Not sure what is happening with kepler there.
III-V
678
You need both bandwidth, as well as ROP count. Nvidia manages such high fillrate because of superior color compression on GM204 compared to Hawaii (which doesn't have the significant compression improvements that Tonga does), which allowed them to double the ROPs while keeping them reasonably fed.
raghu78
4,093
1,475
Fixed it for you.
You didn't even post till I posted. Way to single me out raghu78.
somebody needs to fix this fixer. everybody know who is the butt of all jokes on ocn, semiaccurate, anandtech etc. Your posts are to put it aptly entertainment to some and pure trash to others :whiste:
NTMBK
10,297
5,289
Seronx- Basilisk was never openly confirmed, only appearing on a handful of LinkedIn profiles. For all we know it could be cancelled- and probably is, given that AMD are trying to get people to focus on K12 and Zen.
NostaSeronx
3,701
1,230
NostaSeronx
3,701
1,230
But what makes you think that's Excavator?
Any Bulldozer(15h) architecture after 2015 is obviously Excavator.
Also that Bhavani sounds rather like Carrizo's desktop variant :>
http://support.amd.com/Documents/kb/PEC-1 Files/MDDS_UOL721_(FS1B).pdf
http://www.heise.de/newsticker/meldung/AMD-Athlon-und-Sempron-kehren-wieder-2125393.html
FS1B = AM1
Carrizo 2015 -> Quad-core Excavator + 8 CU GCN IPv8
Basilisk 2016 -> Octo-core Excavator+ + 16 CU GCN IPvX
Zen 2016/2017 -> Quad-cluster Zen + 16? CU GCN IPvX
I do not expect a scenario like Broadwell and Skylake.
(If Basilisk follows Carrizo, December 2014 launch -> December 2015 launch, everything will be okay roadmap wise)
NostaSeronx
3,701
1,230
What's your source for Basilisk being 15h?
AMD
Bulldozer pre-2009 had four nodes(20nm/14nm counts as one) with accompanying APUs each.
45-nm SOI; CPU "Montreal" - Bulldozer // APU "Swift" - Stars // APU "Falcon" - Bulldozer
32-nm SOI; CPU "Sandtiger/Interlagos(Abu Dhabi)/Terramar" - Piledriver // APU "Llano" - Stars // APU "Trinity/Richland" - Piledriver
At this point is when the roadmap explodes.
28-nm SHP/22-nm SHP; CPU "Dublin/Boulder" - Steamroller // APU "Kaveri" - Steamroller
28-nm A/20-nm SHP/20-nm LPM; CPU "Austin" - Excavator // APU "Carrizo" - Excavator
14-nm Bulk/SOI FinFET; CPU "Gecko" - Excavator // APU "Basilisk" - Excavator
Underlined equals cancelled, and italics/bolds unconfirmed if being produced.
14nm FinFET Bulldozer is the last Bulldozer(15h) microarchitecture planned.
iGPUs
Swift/Falcon -> 160 ALUs + 40 SFU // Vec4+Scalar1
Llano -> 320 ALUs + 80 SFU // Vec4+Scalar1
Trinity/Richland -> 288 ALUs + 96 SFU // Vec3+Scalar1
Kaveri/Carrizo -> ~512 ALUs // Vec16
Basilisk -> ~1024 ALUs // Vec16
Regardless, end of 2015 to end of 2016 is the range for 1024+ ALU/Shaders.
szatkus
16
Don't know how you did you get details about unreleased 45nm Bulldozer, but rest is wrong (even if you count units in iGPU).
K10: 3 ALUs per core
Bulldozer-family: 4 ALUs per module
It's not some kind of secret knowledge, there are a lot of documentation about AMD's cores.
Well, shame. I know about some AMD's design, but I don't know the name. Basilisk APU would fit, but I prefer some proof that Basilisk is Excavator.
