DominionSeraph
- Jul 22, 2009
- 8,386
- 31
- 91
Bahahahaha you have owned yourself so hard I can't stop laughing about it.
So these actors are personally and wholly responsible for making the movies they rake huge profits on? The writers, producers, investors, artists, costume designers, makeup artists, special effects guys, model makers, set designers, etc etc et al, had nothing to do with the process? It sure sounds like the actors are raking in massive profits at the expense of the working class to me!
You should've taken my hint.
How do the actors own the means of production? They don't.
The actors and crew work together to make a product.
When I say don't do a transform if you don't understand the underlying mechanics, I mean it.
Don't try to be clever around me. It's not going to work. I am never going to be shocked into immobility by where you ended up.
Analysis of the spaces between is what I do. I will simply break out my kit and go to work in the spaces you glossed or jumped over in your haste to reach a conclusion.
I will not miss the mistakes that you made, so why use a shit method that leaves a trail of them supporting your conclusion? You only end up owning yourself, as you just have.
*sigh* It seems that only in religious discussion can I find intellectual equals seriously working a different path. For mundane things, it seems that if a person is on a different path, it's because they were simply too stupid to see the turn-off.
I miss the dance through the logical intricacies. Watching blind retards stumble about is no substitute.
