10.7 and Warcraft I, II, Diablo, C&C, Red Alert
GWestphal
1,120
What's the best way to go about running these? Install Win98 SE in VMware Fusion? Is there a vmtools set for win98? Or do I have to get an old school computer to run these?
GWestphal
1,120
I've tried to install either with winXP or 98 in Fusion, but I've had no luck. Compatibility modes don't seem to be doing the trick.
bearxor
6,605
All that stuff should run in Crossover.
Just about everything does except expansion packs it seems. FWIW, I've never had any problems playing any of the C&C games via Fusion and WinXP. Are you running in isolated or integrated mode? Maybe if you're running in integrated mode you should make a new VM just for games that is isolated.
You can also look in to sheepshaver and the OS 9 versions of Warcraft I & II and Diablo.
