1 step DVD backup using DVD Shrink + DVD Decrypter?
Red
3,704
The latest DVD Shrink works great on about 75% of the DVDs I backup. It shrinks, encodes, then burns the DVDs without a hitch. The other 25% have problems... usually about 60% into the encoding process I'll get an "encryption" error that forces me to use DVD Decrypter, which I don't mind. However, that usually requires me to have to restart the process, which sucks. Is there anyway to avoid this? Anyway to simply put the DVD in, and when I come home from work know that I've backed it up successfully? Thanks.
stickybytes
1,043
Dvd Shrink works perfectly for me everytime. I haven't backed up that many dvds though, about 10 so it may be a bug with actual program. Try getting a older version if that worked better for you.
DAPUNISHER
31,680
31,538
Personally I always rip to the HDD with DVDecrypter first, I prefer DVDShrink to access the files from there=zero issues or coasters and I've backed up at least 50 of my DVDs with this method.
Red
3,704
Anyway to automate the process... as in, once Decrypter rips them, have DVD shrink start up and start the process? I'd like to be able to automate this in the mornings when I go to work and the evenings when I go to sleep. Thanks!
jose
2,079
Backed up 200+ dvd's w/ dvdshrink, never a single problem. Which dvd gave you problems ?
Regards,
Jose
DAPUNISHER
31,680
31,538
Regards,
Jose
Dazum! How many versions of shrink have you went through in that time?
