- Apr 24, 2005
- 576
- 0
- 0
Ok heres what im trying to do. I have Windows 7, using Asus P8P67 Deluxe motherboard. It has 2 NIC built in. I have Cable internet as well as a DSL connection. Im wanting to use the Cable for my normal desktop, web, gaming, etc. I want to use the DSL connection for my Virtual Box (VMWare) with XP.
The problem im running into is, when I enable the second connection (DSL), my Windows 7 wants to connect to both of them and everything gets screwed up. Like AIM will work, but web, etc will not. The Windows 7 box has both connections showing in my network and connection sharing tab, I cant figure out just how to make the cable the main connection, and not use the DSL at all. The only way I can get everything working again is to disable the one the DSL connection is on.
Any ideas? Hope that makes sense =)
