1 Monitor 2 Computers
Yellowsun
29
Hello
I have one monitor and two computers the monitor is an old 17" CRT, I would like to be able to connect them together so I don?t have to keep unplugging the monitor each time I want to use one of the computers. I have been told I need a Switch Box, I have been searching but have not found one. Could you help me? It needs to be cheap and from the UK. Will I need anything more?
Regards
Doh!
2,325
What you need is a KVM switch. I just did a quick google for it since you're from the UK.
This place in the UK has some. I don't know anything about online stores in the UK, therefore I don't know if these prices are good or bad. After more thorough research, you may find better deals.
Note: Some of the lower priced ones does not include the necessary cables. So consider the cable costs when shopping around.
