SKORPI0
- Jan 18, 2000
- 18,428
- 2,357
- 136
http://www.trulia.com/homes/photos/...d/21162402-2267-Shippan-Ave-Stamford-CT-06902
House with 16 pictures, not sure if it shows that smoke detectors were installed.
That is it, I am going to install smoke detectors in the house I live in. I have had them in their packaging over a year now since I got them from Homedepot. R.I.P. to those 3 kids and their grandparents.
Wow. You can't even sell a house around here without working smoke detectors installed. My father-in-law bought us new detectors for Christmas a few years ago. Damn are they sensitive. Impossible to make toast without one going off. If you make your toast slightly dark, the one in the next room goes off as well. That level of sensitivity gives you plenty of time to get out (or plenty of time to attack a smoldering fire with one of several fire extinguishers in the house.) I've only once ever had the need for a fire extinguisher. Put gas on an anthill in a crack in the driveway. Then realized, maybe I should burn off the fumes, just in case, so that nothing would be parked over it that could ignite the fumes. Hey, did you know that asphalt can be set on fire? Or that after about 60 seconds of burning, you can see the smoke from an asphalt fire from miles away??
by town code here, all inhabitable rooms have to have smoke detectors now - and hard-wired is the way to go. Basement fire? Your detector in the master bedroom will go off.
Sad to hear this. :\
I have smoke/CO detectors installed in every room. Yes they are annoying every time I have something smoking in the oven, they go off. But it beats dying from the smoke if it ever happens. Cheap and effective. Oh, the city where I live requires it.
Your city requires them to be in every room? Or just 1 per floor?
Title 5 Chapter 5
Fire Prevention Code
Orland Park Village
Code
Title 5 Chapter 5 Page 19
The following buildings shall be classified as residential buildings under this Chapter:
SINGLE-FAMILY DWELLINGS: Residential units designed or used for not more than one-family units.
MULTIPLE DWELLINGS: Residential units designed or used for two (2) or more family units.
SMOKE DETECTOR: An electrical device designed to emit a loud warning signal upon detection of an abnormal buildup of smoke in the area. Such device may be photo-electric or ionization type, and may be powered by self-contained battery or one hundred fifteen (115) volt external power supply. All detectors shall bear the label of a nationally recognized standards testing laboratory which indicates that the smoke detectors have been tested and listed under the requirements of UL 217 (1978).
5-5-3-2 PLACEMENT:
All buildings of residential or mixed occupancy having any residential units shall be equipped with approved smoke detectors in the manner prescribed in this Section.
(7/07)
1. Not less than one approved smoke detector shall be installed in every single-family residential unit and multiple dwelling unit as defined herein. The detector shall be installed on the ceiling and at least six inches (6") from any wall, or on a wall located from six inches (6") to twelve inches (12") from the ceiling, and within fifteen feet (15') of all rooms used for sleeping purposes.
2.
All multiple dwellings as defined herein, and buildings of mixed occupancy having any residential units, shall contain not less than one approved smoke detector at the uppermost ceiling of all
interior stairwells. All approved smoke detectors herein required shall be installed on the ceiling,
at least six inches (6") from any wall, or on a wall, located from six inches (6") to twelve inches (12") from the ceiling.
3. In residential buildings having basements or cellars, one additional smoke detector shall be installed in the basement or cellar in a location therein approved by the Building Department.
5-5-4 PENALTY:
Any person, firm or corporation violating this Chapter shall be fined not less than Fifty Dollars ($50.00) and not more than Seven Hundred Fifty Dollars ($750.00) for each offense and a separate offense shall be deemed committed for each and every day during which a violation continues or exists.
(Ord. 4254, 6-18-07; Amd. Ord. 4342, 3-3-08)
Makes me feel a little better about shelling out $2200 for a fire sprinkler system for the house i'm renovating. Even a closet greater than 3'X2' had to have a head
Wow, I've thought of doing that, but that's quite a lot of work, and I'd be worried one triggers by error. Then again they are all over commercial buildings and you never hear of one going off accidentally.
What did you do as far as pressure goes? Residential water lines don't quite have the flow required for a typical sprinkler system. Did you have to setup some kind of pressurized holding tank with a pump?
One thing I would want to do if I was to build a new house is have interconnected fire detectors though, and have them "zoned" so all of them will report to a central station. But right now I have the one that can report so it's better than nothing. To me a fire system has two purposes. Save lives, and save the building. If you are not home, it's job is to save the building. You want the fire department to be notified as soon as a fire breaks out so they can go.
