alfietooch
Hi im from the Philippines.. I have 2 very good deals on both chips.. Basically in terms of dollar to peso ratio.. the diff will only be 10$ for both chips.. ex: $127 for the 1.8a w choice of stock fan or avc sunflower.. then 1.6a $117w stock retail fan only... question are both chips going to oc w fsb to 133 easily? or no guarantee? or will it depend on the pack date etc? any marking i should check on the proc itself to identify if its good for oc or not? i just want to conservative oc.. for stability purposes.just a simple 133fsb bump... are both guaranteed 133??? i capture vid using my vid card only.. i hope this is not affected..the capture process..since pci is increased.. but ive had luck so far using 140/35 on my xp(1800+)1900+.. w/c one would be better???? also.. w/c is better kingston 256mb 333ddr 5ns or samsung 256mb 333ddr ut 6ns??? dont know the exact specs of the memory.. but w/c would oc better? ill keep my kingmax ddr on the xp any advice will be greatly aprreciated.
