1.6a @ 2.4 temps
TenEgg
269
Can you guys tell me your temps when your 1.6a is at 2.4 with stock hsf?
Mine gets up to 57C when running prime95. I think that's too high right? I think I didn't apply AS right. I'll probably redo it.
o1die
4,785
Your temps are ok. I wouldn't be concerned. Besides case flow, other factor is room temperature. You can also switch to a dual fan power supply to reduce temps.
oldfart
10,207
Yeah, Abit tends to report on the high side. I'd say you are ok. The AS will help some. I run ~ 52C 1.6A @ 2.4 1.65 Vcore stock HS/F with ASII on an Epox 4BDA2+.
Egrimm
1,420
A while since I used the stock hsf and were at 2.4 :p, it was 42C under load if I remember correctly.
Edit: this is on an Asus P4B533-E and the case temp was 36C.
aceO07
4,491
My 1.6a @ 2.4 is 51c while running prime95. My other stressing programs such as seti or counter strike :) only get it up to 48c. I don't think you have anything to worry about.
