- Mar 15, 2002
- 126
- 0
- 0
Hello there,
I just wanted to run my system across your guys and see if it sounds ok to you.
The 1.4mhz Athlon Tbird is running at 47 idle, 53.5 max under 100% load(ripping divx)
System specs:
- I get the temp from Compunurse temp gauge taped directly to the processor right next to the core.
- Epox 8k7a mobo - It's temps read 41 idle and 46 under 100%
- Evercase 4252
- Clear globe 120mm fan intake on the front
- Panaflo 80mm L1A intake on side
- Panaflo 80mm L1A exhaust on back and in PS
- Generic heatsink 60mm fan with artic silver 3 ( it's looks a bit like a Volcano 6cu)
I have a Thermaltake 7(non-plus) in transit right now, hoping that may help out a bit.
I also have a baybus fanbus on the way, doesn't look like I'll get much use out of it though unless I upgrade the fans to higher speeds.
Let me know what you think!
System specs:
- Evercase 4252
