I have a 786GM-US2H that I just managed to kill last night while testing my brand-new Thermaltake Frio OCK to replace my dual-fan Hyper 212+ on an overclocked, overvolted 1090T.
The good news is that there was >10C difference between the two. The Frio OCK is much louder (still better than AMD's stock heatpipe cooler at full blast, though), but there's a knob to control it, and fan control software in both Windows and Linux are so efficient that it is not a real problem for me in daily usage.
The bad news, of course, is that a mere 15 minutes in P95 small fft ended up killing the board. This is not a new board - it housed an Athlon X2 7750 and a Phenom II 965 BE before the current 1090T. It could very well have died of abuse (or "natural enthusiast causes").
However, one thing that worries me is that it might be the CPU fan header that caused the catastrophic failure. I'm pretty sure most cpu fan headers are only rated for 1A, and the Frio OCK (to my surprise) is rated at 1.2A (2x 130mm fans on one header). I don't know why I missed that. If I remember correctly, most CPU fan headers can only handle 1A, and only the highest end mobos go up to 2A. I just can't seem to verify this information from motherboard manuals.
I'm not sure if this is a valid concern, so I'm throwing this out to the Cooling gurus here. How likely is it that it was the CPU fan header causing the catastrophic failure of the mobo due to having to power the Frio OCK's dual fans?
