This test was done for2 reasons...1) To disspell the myth of a handful of knuckleheads who think cause they run 1:1 though the cas timings may be weak means it equal to a much higher clocked cpu...2) To prove to myself I have the optimal setup of memory and speed for this Abit mobo which I clearly think shows abit has problems....
Test systems:
p4 2.6@3.033ghz w/ 1:1 for 466mhz ddr cas 2.5,7,3,3
GAT stop functioning at 446mhz ddr, and cas 2,7,3,3 stopped at 446mhz ddr.
p4 2.6@3.2ghz w/ 3:2 for 38mhz ddr cas 2,5,2,2 spd
NO Gat cause Abit version 18 wont boot Gat settings no matter the cas speed or how much you underclock.
I tried CPC enabled/disabled...cas 2.5 to 3,8,4,4...NB trap 800 to By CPU.....NO POST
p4 2.6@3.2ghz w/ 5:4 for 394mhz ddr cas 2,7,3,3
p4 2.6@3.2ghz w/ 5:4 for 394mhz ddr cas 2,7,3,3 CPC enabled (Bios version 14)
Gat works only at turbo but CPC needs to be disabled to run and the GAT results are worse then not having them on.
________________________________________________________________________________________________
-------------------------3.033ghz w/ 466ddr-------3.2ghz w/ 338ddr------3.2ghz w/ 394ddr------3.2ghz w/ 394ddr (CPC)
Sissoft MEM---------------5650's------------------------4800------------------------5380's---------------------5420's
Tmpgenc-------------------2:24---------------------------2:18------------------------2:18------------------------2:17
SuperPi 1M----------------0:45---------------------------0:44-------------------------0:43-----------------------0:43
superPI 2M---------------1:45----------------------------1:43-------------------------1:43-----------------------1:42
Prime95 (ver22)
1792k----------------------76.643------------------------73.320----------------------73.309--------------------73.137
Besweet Wav-AC3------4:25----------------------------4:11------------------------4:08------------------------4:04
DVDshrink 3.0------------17:58--------------------------17:28----------------------17:26-----------------------17:32
Cinebench2003
single cp/multi------------307/363-----------------------323/384-------------------323/381-------------------329/388
AutoCAD 2002------------0:48---------------------------0:46-------------------------0:45-----------------------0:45
WinRAR---------------------3:08---------------------------3:08------------------------3:11-------------------------3:11
3dmark2k1SE-------------9085---------------------------9076-----------------------9077-------------------------Didn't Do
__________________________________________________________________________________________________
3.2ghz to 3.033ghz represents 5.7%
Tmpgenc = 3.033ghz cpu is 5.1% behind fastest 5:4 setting despite 70mhz more and 200+ more mb/s from sissoft...
SuperPI 1M = 3.033ghz cpu is 4.6% behind fastest 5:4 3.2ghz...guess this would to be around 3.15ghz to equal.
SuperPI 2M = 3.033ghz cpu is 1.9% behind fastest 5:4 3.2ghz...guess this would need to be around a 3.08ghz cpu...
Prime95 = 3.033ghz cpu is 4.8% behind fastest 5:4 3.2ghz....would need a 3.16ghz cpu to equal it...
Besweet Wav-Ac3 = 3.033ghz cpu is 8.6% behind fastest 5:4 3.2ghz...Go figure!! Timings mean more I guess..Ran multiple times.
DVDshrink3.0 = 3.033ghz cpu is 3.1% behind fastest 5:4 3.2ghz....would need a 3.12ghz cpu to equal it...
Cinebench 2003 = 3.033ghz cpu is 7.2% behind fastest 5:4 3.2ghz....again it must be the slower timings at 1:1...
AutoCAD 2002 = 3.033ghz cpu is 6.7% behind fastest 5:4 3.2ghz....again this render program cares less about speed vs timings
WinRar = 3.033ghz cpu is 1.6% faster and the only program I tested that was faster then a higher speed cpu with lower speed mem.
3dmark2k1SE = 3.033ghz cpu is equa to higher speed cpu with lower speed memory but I dont think this is a surprise. Many know the 3dmark2k1se as ery non cpu dependent. Memory bandwidth wins in these programs. Sorry it is my only game test but I should have UT demo to test here in a few days to see if this is indictative of gamers.
Conclusion it appears in the apps I run which tend to lean at Mulitmedia, rendering, archiving, Transcoding, and scientific that memory speed does not equate to raw speed and many who sacrifice larger overclocs to run at 1:1 with lower timings are not running their machine optimally. Now I do conclude this is not proven for gaming yet, but it is nowhere near the fantasy numbers I ave heard ppl pull out of their arses around here....It is likely higher speed memory like 466mhz ddr could run at 3.06ghz and equal a 3.2ghz 400mhz 5:4 system as long as the timings are no that much different.
***ADDED***
Test systems:
#1) p4 2.6@3.033ghz w/ 1:1 for 466mhz ddr cas 2.5,7,3,3
GAT stop functioning at 452mhz ddr, and cas 2,7,3,3 stopped at 456mhz ddr.
#2) P4 2.6@3.033ghz w/ 5:4 for 373mhz ddr cas 2.5,7,3,3
#3) p4 2.6@3.033ghz w/ 5:4 for 373mhz ddr cas 2,5,3,3 CPC enabled
-------------------------(#1)3.033ghz w/ 466ddr-------(#2)3.033ghz w/ 373ddr-----(#3)3.033ghz w/ 373ddr
Sissoft MEM---------------------5650's---------------------------5030's----------------------------5100
Tmpgenc--------------------------2:24-----------------------------2:26------------------------------2:24
SuperPi 1M-----------------------0:45-----------------------------0:46------------------------------0:45
superPI 2M-----------------------1:45-----------------------------1:51------------------------------1:49
Prime95 (ver22)
1792k----------------------------76.643--------------------------77.340----------------------------77.142
Besweet Wav-AC3--------------4:25-----------------------------4:28-----------------------------4:22
DVDshrink 3.0-------------------17:58----------------------------18:05----------------------------17:57
Cinebench2003
single cp/multi------------------307/363------------------------305/361--------------------------306/362
AutoCAD 2002--------------------0:48-----------------------------0:49-----------------------------0:48
WinRAR-----------------------------3:08-----------------------------3:25-----------------------------3:19
3dmark2k1SE---------------------9085----------------------------9008-----------------------------9037
UT2003demo(flyby)------------186.82--------------------------185.79---------------------------186.32
UT2003demo(botmatch)--------83.65---------------------------81.30-----------------------------82.46
1:1 vs 5:4 (same timings)/1:1 vs 5:4 w/ cas 2,5,3,3 cpc
Sandra MEM---- 1:1(+12.3%) / 1:1(+10.8)
Tmpgenc-------- 1:1(+1.3%) / 1:1(+0.0%)
SuperPi 1M----- 1:1(+2.2%) / 1:1(+0.0%)
SuperPi 2M----- 1:1(+5.7%) / 1:1(+3.8%)
Prime95--------- 1:1(+0.9%) / 1:1(+0.6%)
Besweet-------- 1:1(+1.1%) / 5:4(+1.1%)
DVDshrink3.0-- 1:1(+0.6%) / 5:4(+0.1%)
Cinebench03--- 1:1(+0.6%) / 1:1(+0.3%)
AutoCAD2002-- 1:1(+2.1%) / 1:1(+0.0%)
WinRAR---------- 1:1(+9.0%) / 1:1(+5.9%)
3dMark2k1SE--- 1:1(+0.9%) / 1:1(+0.5%)
Interpolate as you wish...The cas 2 timings almost negated the memory speed....
Test systems:
Prime95 (ver22)
Cinebench2003
***ADDED***
Test systems:
Prime95 (ver22)
Cinebench2003
