I have been running my 1.1 GHz CPU on an MSI K7t-Pro-2A motherboard. When I run with the Case cover off have a cpu temp. of 113-118 degrees F. When I run it with the case cover on it reached 135 approx. and my system crashes. What are you doing to keep the heat down?
I am using an AMD appoved fan. I am considering a water cooling solution. Please advise.
