YMMV on this deal.. but if you can find it.. i think it's a good buy. They had these in Blue, Red, and Clear. The selection will probably vary from store to store and the stock is limited.. so I would check it out ASAP if you wanna score some.
These are availible at the "$0.99 Only Store" chain that are all over So. CAL.
I don't know if these store exist outside of So. CAL.
Good luck
Good luck
