“godfather” of the iPod invents world’s first learning thermostat
TraumaRN
6,893
63
This would actually work well for me given my shifts as a nurse. It's generally changing a lot. I only work 3 sometimes 4 days a week so this would be the perfect thing for me. I've got my current programmable thermostat set up as best I can given my schedule, but I'd be willing to bet I could shave another 5-10% off my heating bill in the winter with this, ditto in the summer time.
However...it needs to be no more then $125....at it's current price it's too expensive.
Lithium381
12,452
has potential, but too expensive for the moment.... my thermostat isn't programable, i don't have central air so i suppose it doesn't matter anyway
KillerCharlie
3,691
68
I've been thinking of that idea for quite a while, I'm surprised it took this long to come out. It seems like a pretty simple way to save energy. The whole benefit is that it's not stuck to a schedule. Some days I might come home 4-5 hours later than other days. Of course the energy savings is pretty small.
The price is way too high though.
Howard
47,982
10
WTF flathead screwdriver? For that money I should be getting at least a Robertson, Allen, or Torx drive.
zinfamous
111,095
30,041
I don't get it. A friend in Switzerland, who has two other houses in the Borgogne region of France, has had all of his thermostats hooked up for remote connections for well over 10 years.
He would just phone it in before he arrives, to warm the house up. THis is basically that, with a nice GUI.
pmv
13,572
8,472
Who uses thermostats? I've never understood the point of them (other than in public buildings, I guess).
I turn the heating on when I can't bear the cold, then quickly turn it off again, after 20 minutes or as soon as I reckon I can stand it.
So far this year haven't had the heating on at all. Hoping to get away without it till Christmas at least.
Gas (or whatever you call it in the US to avoid confusion with petrol 'cos you call that "gas" right?) is far too expensive for messing around with automatic control. If I'm going to burn money I want it under my direct control, thanks.
Doppel
13,306
I find this "invention" extremely underwhelming.
I guess people with houses? It's called natural gas in the US and there's so Fing much of it here it's pretty damn cheap ;) Also, you won't make it to Christmas without heat in much of the US. While I'm at it, by golly, they are called flashlights, not torches. Torches have fire.
Miramonti
28,651
100
Lemme guess...no wife...no kids...no visitors...
Eug
23,790
1,361
A friend of mine sent me the site link.
Yeah, I told him the same thing. Total ripoff, and a solution looking to solve a problem that doesn't really exist, at least for 99% of the population. You'd do better with a $50 programmable thermostat.
Blackjack200
15,995
1,686
Ummm, so, people who are too stupid to program their thermostat to lower the temperature when they're not home are going to be able to figure out how to connect this with their wifi, set passwords, figure out how to magically connect to their thermostat while online from a remote location, and figure out how to run the software there to lower the temperature in their house. Then, when they get home, they're going to have to go online, and figure out how to warm the house back up.
Stupid people are going to fail at using this product to do anything useful.
Smart people are competent enough to be able to set a $25 thermostat appropriately.
I gave up programming my thermostat last year and now just set it to the same temperature 5 days a week; morning afternoon, evening, and night. Yes, I know how to program it, but my schedule is never the same two days in a row, so I just turn the heat/AC off when I leave the house and turn it back on when I get back.
I'd like a system that can track my position with my phone's GPS and keep track of my behavior so it can decide when I'm on my way home and start heating/cooling the house then. Probably years away from that though :(
Wyndru
7,318
4
The Nest thermostat adjusts its behavior dynamically to make sure users are comfortable when they’re at home while at the same time saving energy while they’re away—even if that time away wasn’t part of the thermostat’s programming.
Am I missing something? This device automatically knows when you aren't in the house for extended periods of time?
seepy83
2,132
http://support.nest.com/customer/portal/articles/178864-what-is-auto-away-
I started going through their website today to see if they have answers for a lot of the doubts that came to mind first. If you look through the various pages and the Support page, they have a lot of information about the device. You can set your own schedules on it, turn learning on and off, etc. The features and functions are nice, but the price is way too high.
I'm curious about what patents they hold for this device. If it creates a lot of buzz, I could see Honeywell and other thermostat manufacturers producing a very similar device at a lower price.
FoBoT
63,082
12
fobot.com
or it could be a USB device you plug into your computer, the device would just contain the sensors and the 'smarts' would be software on your computer, why does it need to sit on the wall?
Wyndru
7,318
4
Ahh, thanks, I figured it had to be some kind of motion/light sensor. I guess that means this thing needs to be placed in a location that people will be walking around in frequently to be effective.
seepy83
2,132
I'm pretty sure that thermostats need to be located in specific areas so that the HVAC system can work correctly. For example, you don't want it located right next to a heating vent or radiator because it's going to detect a much higher temperature than what the ambient temp in the house actually is. Computers produce heat, so you really wouldn't want your thermostat to be plugged into a USB port.
Edit: Also, the thermostat need to be wired to the furnace, A/C, boiler, etc. At some point it need to send an electrical signal to tell the equipment to turn on the heat or cool the building.
TwiceOver
13,544
44
It would take over 10 years for me to save the initial investment. Not enough "cool" factor for me to pay out for something with that long of a return.
