Hi,
I'm new to linux and I'm having trouble installing a printer on Ubuntu 9.10.
Printer Model: Brother MFC-7820N
Multifunction Network Printer with Fax and Scanner.
The local network has 2 computers and this printer. One computer has Windows XP Pro (which I don't have access to), and the other has Linux Ubuntu 9.10.
First I try installing the printer directly without any extra drivers. In System->Administration->Printing the printer was detected without any problem, brand, model and IP with no problem.
It installed okay, but page testing sent nothing. I then openned up the printer and manually sent a page test. No problem, ubuntu test page printed successfully.
But the problem is that when printing a PDF or a Word document, it printed some scrambled chars, picked lot's of pages for doing so (when the document was only 1 page length) and nothing more.
Once I turned the printer off and back on, just to find it had lost (at least) it's IP configurations ... I had to manually configured it's IP again.
Then I tried drivers from brother site, with no success, same problems.
The person from Windows machine started to have problems printing too ... so no-one can print now.
Looking for more info, I found http://www.openprinting.org/show_printer.cgi?recnum=Brother-MFC-7820N which has some info about drivers to work with printer, but also raises a lot more questions for a new person to linux.
I tried a new trick:
1. Deleted the printer, no printers installed at all;
2. Selected "New ..."
3. The printer was not present. No problem.
4. Selected Network Printer->LPD/LPR Host or Printer;
5. Inserted the IP address: 192.168.1.50
6. Clicked Probe ... and the queue appeared with "lp" selected;
7. Then latter on, I provided the custom PPD file obtained here: http://www.openprinting.org/foomatic-db/db/source/PPD/Brother/BR7820_2_GPL.ppd
8. Apparently it installed correctly ... the printer had a different icon
9. Testing, and the problems still there.
Printer result:
error name:
configurationerror
command;
setpagedevice
operand stack;
dicttype
What else should I try?
I also have a bunch of new questions:
1# Is it possible that this driver testing could cause some misconfiguration on the printer? So that the Windows computer now doesn't print anymore?
2# The Foomatic is the System->Administration->Printing gui for installing printers?
3# Looking for some info, I found about known printer spooler (CUPS, LPRng, LPD, GNUlpr, PPR, PDQ, and spooler-less printing). So which one to choose? Are they compatible with a printer when Windows and Linux both print to them? Which should be the most compatible?
4# Should I get a fresh linux install and retry this custom PPD installation, without any brother drivers throwed in?
Thanks
Printer result:
error name:
configurationerror
command;
setpagedevice
operand stack;
dicttype
Thanks
